Введение
Follow this guide to replace an aging LG G6 battery.
If your battery is swollen, take appropriate precautions.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
For reference, the backside of the panel is shown in the first photo. Note the clearance between the edge of the panel and the fragile ribbon cable beside the fingerprint sensor.
Be careful as you slice and pry to the left side of the fingerprint sensor, as seen from the outside of the phone in the third photo.
Use a hairdryer, a heat gun, or prepare an iOpener and apply it to the lower edge of the G6 for about a minute to soften up the adhesive underneath the rear glass panel.
Secure a suction cup to the rear panel, as close to the heated edge as possible.
If you don't have a small object for propping, you can (carefully) perform this step at the edge of a desk or table to achieve the same angle of entry.
Lift the rear panel's bottom edge with your suction cup, opening a slight gap between the panel and the frame.
Once you've created a gap, press the flat end of an opening tool into the gap.
Slide the opening tool back and forth across the bottom edge of the phone, cutting through the adhesive securing the rear glass panel.
Once the adhesive is cut and the gap is wide enough, insert an opening pick into the gap to keep the adhesive from re-bonding. Remove the opening tool.
Additionally, you can use multiple opening picks for this process, leaving one in place on each side after you finish slicing to prevent the adhesive from re-adhering as it cools.
Slide the opening pick along the left edge of the phone to slice through the adhesive securing the rear panel.
Re-insert the opening pick into the bottom edge of the phone and slide it up the right edge of the phone, cutting through the adhesive holding it in place.
Carefully slide an opening pick across the top edge of the phone, separating the last of the adhesive securing the rear glass panel.
Once all the adhesive is cut, use an opening pick to pry up the rear glass panel.
Remove the panel.
Use tweezers to peel away any remaining adhesive from both the rear panel and the phone's chassis.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Peel away the replacement adhesive's liner, align it with the back of the phone, and press it into place.
Remove any remaining liners, and replace the rear glass panel.
After installing the rear panel, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
Remove the four Phillips screws holding down the lower antenna shield.
Insert the point of a spudger into the small gap between the lower antenna shield and the metal frame of the phone.
Gently pry up the antenna shield and remove it from the phone.
Insert the flat end of a spudger into the small gap between the upper antenna shield and the phone chassis and pry up, releasing the clips holding the shield in place.
Remove the upper antenna shield and wireless charging coil.
Use a spudger to pry up the press connector at the end of the battery's ribbon cable, disconnecting the battery.
Use tweezers to lift up the blue pull tab at the bottom of the battery.
Firmly grasp the blue tab and pull directly upwards, lifting the battery up and out of the phone.
If you encounter significant resistance or the battery starts to deform, refer to the next step for some alternate removal methods.
Prepare an iOpener and apply it to the screen opposite where the battery sits. The heat will help soften the adhesive holding the battery down. Do not apply the iOpener or any other form of heat directly to the battery.
Apply some high-concentration isopropyl alcohol or adhesive remover along the bottom of the battery and then tilt the phone so the liquid will run along the bottom of the battery and weaken the adhesive. Then wait a few minutes and try removal again.
Carefully slide the flat end of a spudger under the battery to slice through the adhesive and lever the battery out of the phone.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted back to 100%.
32 участников успешно повторили данное руководство.
Комментариев: 6
Parfait! j’ai changé ma batterie sans problèmes grâce à ce tutoriel. Merci à Taylor et Claire!
Avec plaisir Nil :)
Pretty good tutorial!
Do I have to recalibrate the battery somehow?
Hi Andreas,
Follow the battery calibration steps listed in the conclusion box to calibrate your new battery.
I would have liked instructions on how to install the new rear cover adhesive from iFixit at the end. The notches in the adhesive didn’t line up with anything.
