LG G6 SIM Card Reader Replacement
Выберете то, что вам нужно
    • Insert wisdom here.
Заключение
MovilOne
Участник с: 06/17/14
2 480 Репутация
Автор 14 руководств
3 Комментариев
Nice Work. Instead of using the iron to solder it to the board, could you use a heat gun instead?
B Thomp - Ответить
Yes, use leaded solder and small amount of no clean flux, maximum heat of 250 c, as described my Molex datasheets and part will self align
Greg Hamilton - Ответить
We have repaired many of these LG G6 phones with damage to the sim card reader, it looks like it is a very common issue with this phone. The sim card tray gets stuck or jammed inside the reader, and when force is applied to pull the tray out, it ends up damaging the pins for the sim card or memory card reader. It is easily repaired though if you have the correct tools and skills!
smartfonefix - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 4,295
