Введение
Many of the hardware repairs require access to the internal components of the device. This guide will show you how to remove the back panel of the LG Incite to access the internal hardware.
Инструменты
Запчасти
Никакие детали не требуются.
Place your thumb under the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
Place the plastic opening tool in the small slot in the bottom left-hand corner.
Pry the battery upward to remove it.
Using the #00 Philips screw driver, unscrew the four 4.5mm screws located on each side of the device.
Wedge the plastic opening tool between the screen and the case.
Gently move the tool along the edge to loosen the screen from the casing. Repeat this for the entire outer edge of the screen.
Flip your phone over to the battery side.
Insert the plastic opening tool into the lower seam between the frame and front cover to separate the back panel.
