LG Incite Camera Replacement
Выберете то, что вам нужно
  1. LG Incite Camera Replacement, Battery: шаг 1, изображение 1 из 1
    • Hold the phone camera-side up and locate the rear cover.
  2. LG Incite Camera Replacement: шаг 2, изображение 1 из 1
    • Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
  3. LG Incite Camera Replacement: шаг 3, изображение 1 из 1
    • Place the plastic opening tool in the small slot below and to the left of the battery.
    • Pry the battery upward to remove it.
  4. LG Incite Camera Replacement, Back Panel: шаг 4, изображение 1 из 1
    • Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
  5. LG Incite Camera Replacement: шаг 5, изображение 1 из 1
    • Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
    • Gently move the tool around the perimeter of the screen to separate it from the body.
    • You should not completely separate the screen from the device in this step.
  6. LG Incite Camera Replacement: шаг 6, изображение 1 из 1
    • Flip the device over so the battery compartment faces up.
    • Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
    • Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
    • The volume, lock, and camera buttons are loose, so be careful not to misplace them.
  7. LG Incite Camera Replacement, Camera: шаг 7, изображение 1 из 2 LG Incite Camera Replacement, Camera: шаг 7, изображение 2 из 2
    • Locate the camera near the upper-left corner and use the metal tweezers to carefully detach the black tab.
  8. LG Incite Camera Replacement: шаг 8, изображение 1 из 3 LG Incite Camera Replacement: шаг 8, изображение 2 из 3 LG Incite Camera Replacement: шаг 8, изображение 3 из 3
    • Carefully slide the metal tweezers underneath the camera in order to lift it out.
    • Do not puncture the gold lining surrounding the camera.
    • The camera is glued in place, so there may be a slight resistance.
Заключение
Еще один человек закончил это руководство.
Kimberly Kha
Участник с: 04/16/13
163 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 2-18, Maness Spring 2013 Участник Cal Poly, Team 2-18, Maness Spring 2013
CPSU-MANESS-S13S2G18
4 членов
Автор 11 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 552
