Введение
If your camera fails or will not turn on, use this guide to replace your camera.
Выберете то, что вам нужно
Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
