LG K20 PLUS Ear Speaker Replacement
Выберете то, что вам нужно
  1. LG K20 PLUS Ear Speaker Replacement, Remove the back cover and battery: шаг 1, изображение 1 из 2 LG K20 PLUS Ear Speaker Replacement, Remove the back cover and battery: шаг 1, изображение 2 из 2
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. Careful: steps 2-3 are sourced from a guide that's marked as in-progress.
    LG K20 PLUS Ear Speaker Replacement, Midframe: шаг 2, изображение 1 из 1
    • Remove 11 Philips screws.
  3. LG K20 PLUS Ear Speaker Replacement: шаг 3, изображение 1 из 2 LG K20 PLUS Ear Speaker Replacement: шаг 3, изображение 2 из 2
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
  4. LG K20 PLUS Ear Speaker Replacement, Rear-Facing Camera: шаг 4, изображение 1 из 1
    • Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
  5. Careful: step 5 is sourced from a guide that's marked as in-progress.
    LG K20 PLUS Ear Speaker Replacement, Motherboard Removal: шаг 5, изображение 1 из 1
    • Using the tip of a Halberd spudger or an opening pick, disconnect the display flex cable from its socket on the motherboard.
    • Starting from the bottom, insert an opening pick between the motherboard and frame and lever apart.
    • Be careful not to break the long section of the motherboard.
    • The top part of the motherboard is lightly adhered to the frame.
    • After the motherboard is removed, compare the original and replacement part. Some components may already be installed on the replacement display assembly.
  6. LG K20 PLUS Ear Speaker Replacement, Ear Speaker Removal: шаг 6, изображение 1 из 1
    • The flex cable and speaker are held in with adhesive. Use heat to soften the adhesive.
    • Carefully insert a Jimmy between the flex cable and the frame and detach the cable from the adhesive.
    • Then use the tip of a metal spudger to continue carefully prying the ear speaker up out of its housing.
Заключение
2 участников успешно повторили данное руководство.
Patrick
Участник с: 05/14/14
6 577 Репутация
Автор 21 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 12
За всё время: 1,050
