Введение
This guide will show you the steps to replace the front-facing camera for the LG K30.
This is a relatively easy fix, but please be sure to go slow and steady when replacing the front-facing camera so that you do not accidentally tear any of the wires or damage the connecting points.
Выберете то, что вам нужно
Power off your Phone before beginning disassembly.
Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
Use the flat end of a spudger to detach the battery connector from the logic board.
