Введение
Your carrier will provide you with a removable 3.7V Lithium Ion battery, which is the power source of the phone. While using the phone, you might need to remove the battery to access other components of the phone.
  1. Begin by taking the back battery cover off. Put your index finger on the white notch and apply pressure.
    • Begin by taking the back battery cover off.
      • Put your index finger on the white notch and apply pressure.
      • While applying pressure, move your hand backwards to slide the battery cover off of the body of the phone.
  2. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Remove the battery. Put your index finger in the notch above the battery near the top of the casing.
    • Remove the battery.
      • Put your index finger in the notch above the battery near the top of the casing.
      • While applying pressure against the battery, lift up and take out the battery.
Заключение
Preston Brown
Участник с: 12.04.2012
22 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 6-20, Amido Spring 2012 Member of Cal Poly, Team 6-20, Amido Spring 2012
CPSU-AMIDO-S12S6G20
4 членов
Автор 10 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 2
За всё время: 1,005
