Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide will teach you how to remove the battery from the LG LX160
  1. Place the phone on a flat surface with the back facing upward.
    • Place the phone on a flat surface with the back facing upward.
    • Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
  2. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  3. Once the panel is removed, you will see the battery.  Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
    • Once the panel is removed, you will see the battery. Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
  4. Remove the battery completely from the phone and place the battery off to the side.
    • Remove the battery completely from the phone and place the battery off to the side.
Заключение
David Baruela
Участник с: 14.01.2010
1 Репутация
1 руководство автора
Команда
Cal Poly, Team 11-2, Forte Winter 2010 Участник Cal Poly, Team 11-2, Forte Winter 2010
CPSU-FORTE-W10S11G2
5 членов
Автор 10 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,139
