LG LX160 Motherboard Replacement
Выберете то, что вам нужно
  1. LG LX160 Motherboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Place the phone on a flat surface with the back facing upward.
    • Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
  2. LG LX160 Motherboard Replacement: шаг 2, изображение 1 из 1
    • Once the panel is removed, you will see the battery. Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
  3. LG LX160 Motherboard Replacement: шаг 3, изображение 1 из 1
    • Remove the battery completely from the phone and place the battery off to the side.
  4. LG LX160 Motherboard Replacement, Motherboard: шаг 4, изображение 1 из 1
    • Before continuing pull off all the rubber tabs to the headphones, and the power input.
  5. LG LX160 Motherboard Replacement: шаг 5, изображение 1 из 1
    • Now turn the phone so that you can see the back where the battery was. Using a screw driver, unscrew the 6 screws holding the back casing together.
  6. LG LX160 Motherboard Replacement: шаг 6, изображение 1 из 1
    • At the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
    • Gently pull up on the orange wire until it comes loose. It may take some force so do not be concerned with being overly gentle.
  7. LG LX160 Motherboard Replacement: шаг 7, изображение 1 из 1
    • After pulling on the orange wire it should come loose like the image.
    • Be sure that the black chip on the underside of the orange wire is all the way out like in the picture before continuing to the next step.
  8. LG LX160 Motherboard Replacement: шаг 8, изображение 1 из 1
    • Now you can remove the logic board from the casing, and set it aside.
    • If you're replacing the logic board insert the board into the phone and attach the phone via the small orange tab
Заключение
andrew toney
Участник с: 01/13/10
1 Репутация
1 руководство автора
Команда
Cal Poly, Team 11-2, Forte Winter 2010 Участник Cal Poly, Team 11-2, Forte Winter 2010
CPSU-FORTE-W10S11G2
5 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 2,307
