Введение
You will need to use this guide if your volume buttons are not working or are worn down.
Выберете то, что вам нужно
Use a plastic opening tool to remove the back cover.
Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
Use a plastic opening tool to remove the back trim by working around all of the edges.
Еще один человек закончил это руководство.
