Введение
This guide will assist you in replacing your phone's faulty camera.
Выберете то, что вам нужно
Use a spudger to remove the two screw covers below display.
Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
Note: Side buttons may fall out when removing the front case. Do not misplace them.
Note: Each side button will only fit in the side that it came from.
Insert a spudger between the black and grey casings and gently spread them apart.
Work around the device gradually, opening the gap further.
Use the spudger and lift upward to disconnect the ribbon from the main part of the phone.
Carefully remove any parts stuck to the front case such as speakers.
Disconnect the ribbons on both sides of the camera by prying them up with a spudger.
Hold the wiring out of the way and pull up with a spudger behind the camera.
The camera unit should come unglued and separate from the phone.
