Введение
This guide will help you through the process of replacing the LG Muziq's keypad.
Выберете то, что вам нужно
Slide the battery cover release towards top of phone.
Place one finger at each side of the battery cover.
Lift and remove the battery cover.
Use the spudger to lift up the two screw covers at the top of the phone.
Remove all four Phillips#00 (3.3mm) screws with screwdriver.
Use the spudger to lift up the rear case from the phone.
Remove the rear case from the device.
Open the phone to expose the keypad.
Use your finger to push the keypad from the front towards the circuit board.
Remove the keypad from the phone.
