Введение
This is a replacement guide on how to replace your back camera unit on your LG Optimus F3.
Выберете то, что вам нужно
Remove the battery cover. Unsnapping each corner will allow the cover to come off.
Separate the rear plastic case by inserting the opening tool between the seams on all sides.
Use a plastic opening tool to detach the connector between the back camera and the motherboard.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use the tweezers to remove the camera by pinching the sides and carefully pulling up.
2 человек успешно провели ремонт по этому руководству.
