Введение
This guide will show you how to properly replace your broken LG Optimus F3 Headphone Jack. Please make sure to have the listed tools and parts before you get started.
Выберете то, что вам нужно
Place your thumb at the bottom of the phone's back where the charging port is located.
Gently pull the cover off.
Using the indent at the bottom of the battery, lift and remove the battery from the phone.
Gently grab the headphone jack along the sides with tweezers.
Lift the headphone jack out of its socket.
Insert the new headphone jack into the headphone socket by lining up the connectors and gently pressing down.
To reassemble your device follow these steps in reverse order.
4 участников успешно повторили данное руководство.
