Введение
If you need to put in a new SIM card because you changed carriers, follow this guide.
When the back cover is completely removed, locate the sim card slot. It should be right above the the battery and it is clearly labeled “Micro Sim”
Use the fingertip cutout to help push the old sim card out. The sim card should exit toward the direction of the battery
Почти готово!
Финишная черта
