Введение
This guide will guide you step-by-step on how to replace the screen on the LG Optimus L9 smartphone. This requires the knowledge of removing the motherboard. Make sure to work in a static-free environment to avoid damaging the components. Make sure to be extra careful with removing the connections as this may lead to permanently damaging them.
Выберете то, что вам нужно
Start by placing the device face down and remove the back cove.
Remove the battery from the phone by lifting it using your finger or the prying tool
Remove all 10 of the 4.5mm Phillips screws that holds the back frame to the case of the phone
Using a small plastic prying tool, carefully remove the back frame by prying on the sides of the device.
Using a spudger or small prying tool, lift up the motherboard from the chassis of the device.
Using a spudger or small prying tool, pry off the latches that connects the digitizer to the chassis carefully.
Once the digitizer has been removed, turn the phone face down and remove the plastic housing for the front speaker. It should come off easily.
Slide off the connector through the hole of the chassis slowly to avoid damaging it.
Еще один человек закончил это руководство.
