Введение
This guide will show you step by step instructions on how to replace the camera on your LG Optimus T.
Выберете то, что вам нужно
Use a plastic opening tool to remove the phone's back cover. At the top of the phone there are indentations to insert the spudger and pop the case off
Remove the battery by pulling up on the battery using the indentation to the left of the camera lens
Remove interior case using indentations on the top and bottom to insert the spudger to pop off the interior case
Remove SD card mount by inserting the plastic opening tool on the right side of the device to pop mount off
Remove metal panel by inserting plastic opening tool into the four retaining points and remove panel
Инструмент, используемый на этом этапе:Tweezers$4.99
disconnect camera connector from motherboard by spudger
Once disconnected, remove camera using tweezers
