Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide if you are looking to gain access to the LG Risio Motherboard or other components inside the device.
Выберете то, что вам нужно
Use a plastic opening tool to seperate the back panel from the device.
Remove the back panel.
Place your thumb along the bottom of the battery and pry upwards to remove.
Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
