Введение
If the rear-facing camera is taking photos that are blurry, replacing the camera may fix that issue. Use this guide to replace the rear-facing camera.
Выберете то, что вам нужно
Use a plastic opening tool to seperate the back panel from the device.
Remove the back panel.
Place your thumb along the bottom of the battery and pry upwards to remove.
Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
