Введение
If your battery isn’t properly charging or fails to power your device, you should consider replacing the battery. A battery replacement is a fairly simple process for the LG Rumor 2.
Push down on the battery and pull it out from the notch.
Remove the battery from the device.
Еще один человек закончил это руководство.
