  1. Remove the plastic back panel of the phone. Use the small crease to prop open the back casing. Use the small crease to prop open the back casing.
    • Remove the plastic back panel of the phone.
    • Use the small crease to prop open the back casing.
  2. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  3. Find the slot at the bottom of the battery. Use a fingernail or opening tool to pry out the battery. Find the slot at the bottom of the battery. Use a fingernail or opening tool to pry out the battery. Find the slot at the bottom of the battery. Use a fingernail or opening tool to pry out the battery.
    • Find the slot at the bottom of the battery. Use a fingernail or opening tool to pry out the battery.
  4. Use your thumb to gently remove the battery. Use your thumb to gently remove the battery. Use your thumb to gently remove the battery.
    • Use your thumb to gently remove the battery.
Заключение
2 участников успешно повторили данное руководство.
Tiffany Cogswell
Участник с: 18.07.2013
155 Репутация
Автор 2 руководств
Команда
WRI115, Team 1-3, Ruszkiewicz Spring 2013 Member of WRI115, Team 1-3, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G3
4 членов
Автор 2 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 465
