Введение
Is the rear camera on your LG Stylo 3 Plus no longer taking great photos? Removing the rear camera for cleaning or replacement may sound daunting, but it only takes about 5 minutes and some simple tools. Follow this guide to quickly replace your rear camera and continue taking great pictures!
Выберете то, что вам нужно
Place the phone face down.
Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
Place the back cover off to the side.
Insert the opening tool into the small gap below the battery.
Carefully pop the battery out to prevent damage.
Remove the twelve 4mm screws using the Phillips #000 screwdriver.
Use the plastic opening tool to remove the inner case.
Carefully remove the inner case.
Use your fingernail or the plastic opening tool to flip the flex cable.
Use the precision tweezers to carefully grasp and pull out the camera.
5 участников успешно повторили данное руководство.
