Введение
This guide will walk you through the steps of removing the midframe of your LG Sunrise.
Выберете то, что вам нужно
Use a prying tool or a flat head screwdriver to pry the back cover from the device.
Шаг 5 Lower Back Plastic Piece
Careful: steps 5-6 are sourced from a guide that's marked as in-progress.
You will be first removing the two lower screws. This is allow you to remove the lower plastic piece.
Once you have removed all 6 screws. Gently pry all sides of back plastic piece, starting at the bottom. Once you start on the bottom, it will become easier to pry.
Once you have pried off the back piece, the mother board should be exposed. Set this piece aside for replacement or reassembly.
Еще один человек закончил это руководство.
