Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide shows you how to replace the buttons on your LG Thrill 4G.
Turn off your phone before starting.
Выберете то, что вам нужно
Pry open the back cover by using a fingernail or a plastic opening tool.
Remove the three Philips #00 screws from the bottom of the phone.
Two 5.5 mm screws
One 4 mm screw
Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
Place plastic opening tool under the bezel at either the bottom left or bottom right corner of the HDMI cover.
This will loosen the both, the HDMI and USB covers enough, so that you may now pull upwards and pop them right off.
