Введение
This guide will walk you through replacing the display and touch screen on your LG Tribute 5. This can resolve issues such as an unresponsive touch screen, a display that is damaged or does not work, or a cracked glass display. Use caution when handling a cracked display to prevent cuts.
Выберете то, что вам нужно
Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover.
Gently lift the battery out from the compartment.
Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown.
Using an iFixit opening tool, remove the antenna extender located at the bottom.
3 участников успешно повторили данное руководство.
