Выберете то, что вам нужно
Use an iopener to open the back panel and remove it...there will be glue...
Unscrew the screws holding the motherboard cover on...there should be
Remove the motherboard cover and apply adequate pressure because there is some resistance.
Disconnect the yellow ribbon cable connector that connects the battery to the mother board. Make sure to use plastic to remove the battery and pull up on it to break the glue also pull battery pull tabs correctly.
Reconnect the new battery by connecting the ribbon cable connector back to the motherboard.
Repeat steps backwards from step 3 to reassemble the phone.
