Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Shutdown the LG V10 before replacing any component. If your music or other audio emitted from the phone's loudspeaker is distorted but is completely fine when listened through headphones/earphones, then the phone’s loudspeaker may need to be replaced.
Запчасти
Детали не указаны.
  1. Wedge the flat end of the plastic spudger, or the tip of your finger, in between the back cover and the LG V10’s charging port.
    • Wedge the flat end of the plastic spudger, or the tip of your finger, in between the back cover and the LG V10’s charging port.
    • If using a spudger, it should not be in the charging port, but between the metal lining of the charging port and the back cover.
    • Carefully lift up on the spudger or with your finger so that the back cover pops up. The rest of the back cover should easily come off by sliding a finger or spudger under the back cover and around the sides.
  2. There’s an impression next to the battery for the user to use their finger to pry the battery out; pry the battery out using your finger or the flat end of the spudger. There’s an impression next to the battery for the user to use their finger to pry the battery out; pry the battery out using your finger or the flat end of the spudger.
    • There’s an impression next to the battery for the user to use their finger to pry the battery out; pry the battery out using your finger or the flat end of the spudger.
  3. Using a screwdriver with a J000 Phillips bit, remove the ten 3.175 mm screws. Using a plastic opening tool, pry part of the panel up starting from the sides of the battery slot.
    • Using a screwdriver with a J000 Phillips bit, remove the ten 3.175 mm screws.
    • Using a plastic opening tool, pry part of the panel up starting from the sides of the battery slot.
  4. Carefully but firmly pull on the loudspeaker component to release it from the plastic bits holding it in place. Carefully but firmly pull on the loudspeaker component to release it from the plastic bits holding it in place.
    • Carefully but firmly pull on the loudspeaker component to release it from the plastic bits holding it in place.
Заключение
After replacing the loudspeaker, follow these instructions in reverse order to reassemble the LG V10.
Joseph
Участник с: 25.09.2017
855 Репутация
Автор 4 руководств
Команда
USF Tampa, Team S16-G3, Eyestone Fall 2017 Участник USF Tampa, Team S16-G3, Eyestone Fall 2017
USFT-EYESTONE-F17S16G3
2 членов
Автор 4 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 330
