LG V20 Primary Rear-Facing Camera Replacement
Выберете то, что вам нужно
  1. LG V20 Primary Rear-Facing Camera Replacement, Battery: шаг 1, изображение 1 из 3 LG V20 Primary Rear-Facing Camera Replacement, Battery: шаг 1, изображение 2 из 3 LG V20 Primary Rear-Facing Camera Replacement, Battery: шаг 1, изображение 3 из 3
    • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
    • Be careful not to deform or puncture the battery.
    • Pry up and remove the battery.
  2. LG V20 Primary Rear-Facing Camera Replacement, Midframe Assembly: шаг 2, изображение 1 из 1
    • Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
  3. LG V20 Primary Rear-Facing Camera Replacement: шаг 3, изображение 1 из 2 LG V20 Primary Rear-Facing Camera Replacement: шаг 3, изображение 2 из 2
    • The top and bottom frame section hold very tight to the mid frame. It is possible to pull them off with your hands. If you're not able to do so, use the following removal procedure:
    • Use the flat end of a spudger and apply pressure to one of the corners of the frame section until you create a small gap.
  4. LG V20 Primary Rear-Facing Camera Replacement: шаг 4, изображение 1 из 2 LG V20 Primary Rear-Facing Camera Replacement: шаг 4, изображение 2 из 2
    • Flip the phone and insert an opening pick in the gap you created.
    • Slide the opening pick along the gap until the frame section pops out of its plastic clamps.
  5. LG V20 Primary Rear-Facing Camera Replacement: шаг 5, изображение 1 из 1
    • Remove the frame section.
    • Repeat this procedure with the frame section on the other end of the phone.
    • Within the top frame section there's a small silver grating that covers the speaker. This may fall out, so be careful not to lose it.
  6. LG V20 Primary Rear-Facing Camera Replacement: шаг 6, изображение 1 из 2 LG V20 Primary Rear-Facing Camera Replacement: шаг 6, изображение 2 из 2
    • The loudspeaker is attached to the cover of the motherboard. Use an opening pick to pry it up.
  7. LG V20 Primary Rear-Facing Camera Replacement: шаг 7, изображение 1 из 2 LG V20 Primary Rear-Facing Camera Replacement: шаг 7, изображение 2 из 2
    • The cover of the motherboard is held in its place by several plastic clamps.
    • Use an opening pick to pry up the motherboard cover at the right corner at the bottom of your phone until it pops out of the plastic clamp.
  8. LG V20 Primary Rear-Facing Camera Replacement: шаг 8, изображение 1 из 2 LG V20 Primary Rear-Facing Camera Replacement: шаг 8, изображение 2 из 2
    • Slide the opening pick along the mid frame and flip it sideways to open the plastic clamps holding the motherboard cover in its place.
  9. LG V20 Primary Rear-Facing Camera Replacement: шаг 9, изображение 1 из 1
    • Remove the motherboard cover.
  10. LG V20 Primary Rear-Facing Camera Replacement, Front-Facing Camera: шаг 10, изображение 1 из 2 LG V20 Primary Rear-Facing Camera Replacement, Front-Facing Camera: шаг 10, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Use the flat end of a spudger to disconnect the front camera flex cable.
    • If you want to go on and remove the motherboard assembly, there is no need to remove the front facing camera after disconnecting it. However if you feel uncertain, carefully remove it with a pair of tweezers.
    • Use a pair of tweezers to carefully remove the front facing camera. Be careful to only grip the body of the camera, as the top is the sensor pcb and is only held on with glue (removal will ruin the sensor).
  11. LG V20 Primary Rear-Facing Camera Replacement, Motherboard Assembly: шаг 11, изображение 1 из 1
    • Use the flat end of a spudger to disconnect the flex cable of the left rear camera.
    • The second rear camera will come out with the motherboard since it is connected on the other side.
    • You can leave the front facing camera in its place as long as you're careful while removing the motherboard assembly. However if you feel uncertain, carefully remove it with a pair of tweezers.
  12. LG V20 Primary Rear-Facing Camera Replacement: шаг 12, изображение 1 из 1
    • Disconnect the display flex cable with the flat end of a spudger.
  13. LG V20 Primary Rear-Facing Camera Replacement: шаг 13, изображение 1 из 2 LG V20 Primary Rear-Facing Camera Replacement: шаг 13, изображение 2 из 2
    • Use the pointed end of a spudger to lift up the motherboard assembly until you can get a good grip.
    • Carefully lift up the motherboard assembly and remove it.
  14. LG V20 Primary Rear-Facing Camera Replacement, Primary Rear-Facing Camera: шаг 14, изображение 1 из 2 LG V20 Primary Rear-Facing Camera Replacement, Primary Rear-Facing Camera: шаг 14, изображение 2 из 2
    • Flip the motherboard assembly and use the flat end of a spudger to carefully disconnect the flex cable of the rear camera.
    • Use a pair of tweezers to remove the rear camera.
Заключение
6 человек успешно провели ремонт по этому руководству.
Garrett Janney
Участник с: 04/26/17
909 Репутация
Автор 4 руководств
Команда
Cal Poly, Team S22-G5, Livingston Spring 2017 Участник Cal Poly, Team S22-G5, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G5
4 членов
Автор 36 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 12
За всё время: 6,709
