Введение
In this video, I will show you how to replace LG V30 standard or wide-angle back camera.
This guide will show you how to replace both the standard and wide-angle rear cameras in the LG V30 smartphone. If your rear cameras are producing blurry or glitchy photos, or if your cameras are failing to function at all, replacing them should alleviate your issues.
Выберете то, что вам нужно
Видео обзор
Insert a SIM card eject tool into the small hole on the right side of the phone to release the SIM card tray from the phone.
Pull the SIM card tray out from the phone.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Use a suction cup to lift up the back cover up.
Insert the edge of a plastic card into the space created between the cover and frame.
Insert a second card where you have created an opening with the first card and slide it along the bottom edge of the phone.
Continue to slide the cards around the remaining three edges to release the adhesive.
Use the plastic spudger to pry up the four press fit connectors on the top portion of the motherboard.
Use a spudger to pry up the two press fit connectors on the bottom portion of the midframe.
Flip over the motherboard.
Using a plastic spudger, pry up the press fit connector for the first camera.
Pry up the second camera with a spudger.
Remove the second camera with a pair of tweezers.
2 участников успешно повторили данное руководство.
