Введение
If your device isn’t properly taking photos or showing images, the camera may be the underlying issue. Use this guide to replace the front-facing camera in your phone.
Выберете то, что вам нужно
Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
Allow to sit for 1-2 minutes to heat up the adhesive.
Insert an Opening Tool into the seam between the rear glass and side of the phone.
Pry the glass off just enough to insert an Opening Pick.
Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
Gently push down on the small black tab with a Spudger to release the protective board.
Slide an Opening Tool between the phone and the protective board and slide along the edges of the phone to unclip it.
Carefully wiggle the board back and forth while gently pulling to unclip the last attachment point.
Slide an Opening Tool between the lower protective board and the phone to unclip.
Slide the tool along the remaining edges of the protective board until it pops off.
Gently pry each visible ribbon cable away from the motherboard to disconnect them.
Use a Spudger to get between the battery and the phone and pry each edge of the battery away from the board.
Insert Opening Picks if needed to keep the battery elevated.
Use a Spudger to pry away the front-facing camera from the board.
