Выберете то, что вам нужно
Unscrew the 8 screws using a Phillips (PH#00) screwdriver
Using a plastic opening tool , once again pry up on the edges of the plastic back cover.
Gently disconect the screen cable using a spudger.
Using the spudger, pry the motherboard away from the screen assembly.
Use a heat gun or hairdryer to heat up the edges. This will loosen the glue so the screen can be removed.
Continue to heat and separate until the screen comes completely apart from the rest of the phone using plastic tools
9 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
Pls help how can I fix lg-k120e screen
