Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Press the light grey button in the top-center on the back of the phone.
While pressing, slide the battery and cover up.
Unscrew the antenna by grasping the base and twisting counterclockwise.
The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside.
Use a Torx T6 screwdriver to unscrew the four screws on the back of the phone.
With the phone flipped open, wedge the back cover from the faceplate by running the tip of the plastic opening tool around the seam on the back of the phone.
Gently pull the two pieces apart to separate, and set the back casing aside.
Lift the motherboard to gain access to the keypad and side buttons beneath.
Using your fingers or the pointed end of a black plastic spudger, pry the microphone out and replace.
