Введение
Replacing the outer display cover.
  1. Turn the closed phone so that the back panel is facing you.
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. Now just lift up on the battery and remove it from the phone. Now just lift up on the battery and remove it from the phone.
    • Now just lift up on the battery and remove it from the phone.
  3. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Remove 4 rubber grommets using the Spudger.
    • Remove 4 rubber grommets using the Spudger.
  5. Remove 4 screws using the Phillips #00 Screwdriver.
    • Remove 4 screws using the Phillips #00 Screwdriver.
  6. Carefully pry off outer cover using iPod Opening Tool. Carefully pry off outer cover using iPod Opening Tool. Carefully pry off outer cover using iPod Opening Tool.
    • Carefully pry off outer cover using iPod Opening Tool.
Заключение
David Foster
Участник с: 11.04.2010
1 Репутация
Автор 8 руководств
Команда
Cal Poly, Team 25-88, Amido Spring 2010 Member of Cal Poly, Team 25-88, Amido Spring 2010
CPSU-AMIDO-S10S25G88
4 членов
Автор 18 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 1,361
