Введение
This section covers how to disassemble the upper casing of the LG VX5200 to access the phone's screen.
Выберете то, что вам нужно
Pry the grey pieces of plastic off the corners of the screen with a spudger.
Close the phone after removing the screws.
Slide a spudger into the cracks in the top half of the phone's casing.
Wedge and lever the spudger to remove the casing.
Remove the chipboard from the screen by sliding a plastic spudger under the screen and lifting.
Gently lift the speaker out of the plastic casing using a plastic spudger.
Remove the small battery adjacent to the speaker with a plastic spudger.
Slide and lever a plastic spudger between the screen and it's housing.
Remove the chip connecting the screen to the camera using your fingers.
Один комментарий
The “battery” beside the speaker isn’t the battery, it’s the phone vibrator. Still a good guide, however
