  1. Remove the rubber stoppers from the four corners of the front screen.
    • Remove the rubber stoppers from the four corners of the front screen.
  2. Using the Phillips screwdriver, carefully remove all four screws.
    • Using the Phillips screwdriver, carefully remove all four screws.
  3. To pry open the face plate, place the iFixit Opener tool in the crease of the phone. To pry open the face plate, place the iFixit Opener tool in the crease of the phone.
    • To pry open the face plate, place the iFixit Opener tool in the crease of the phone.
  4. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  5. Carefully lift off the black frame around the LCD screen and set it aside. Carefully lift off the black frame around the LCD screen and set it aside.
    • Carefully lift off the black frame around the LCD screen and set it aside.
  6. Lift the speaker out by using tweezers.
    • Lift the speaker out by using tweezers.
    • Next, lift the battery out using the tweezers.
  7. Using tweezers, carefully disconnect the orange ribbon from the computer chip.
    • Using tweezers, carefully disconnect the orange ribbon from the computer chip.
  8. Remove the LCD screen and replace with a new one.
    • Remove the LCD screen and replace with a new one.
    • Finally, replace the battery and the speaker.
Заключение
Ashley
Участник с: 12.02.2013
9 Репутация
Автор 3 руководств
Команда
Ohio State, Team 1-1, Buehl Spring 2013 Member of Ohio State, Team 1-1, Buehl Spring 2013
OSU-BUEHL-S13S1G1
3 членов
Автор 4 руководств
Один комментарий
Thanks for the instructions. By chance, do you know how to replace the motherboard? Where is the mother board
Sula Tremaine - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 396
