Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide requires very little disassembly to complete.
Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
Insert your finger into the small indentation above the battery.
Push down on the battery and pull it away from the phone; it will pop out.
Еще один человек закончил это руководство.
