Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
Insert your finger into the small indentation above the battery.
Push down on the battery and pull it away from the phone; it will pop out.
Grasp the edges of the phone with one hand.
Unscrew the six 5.0-mm Phillips #000 screws located around the outside of the back panel of the phone.
Insert the spudger into the tab at the top of the back panel and push to release the panel.
The back panel will then lift away from the rest of the phone.
Flip the phone open with the back side still facing you.
Grasping the phone on the sides, use your fingers to push up on the keypad and motherboard until they release from the phone casing.
Grasp the keypad and lift it up and out of the phone.
An image of the front of the keypad and phone is shown.
Еще один человек закончил это руководство.
