Введение
The following guide if for removing or replacing the keyboard on the LGVX6000.
Выберете то, что вам нужно
Locate the dark gray tab on the back of the phone towards the top. Push the tab towards the top of the phone to release the battery.
Pull out the two rubber cushions located on the top of the phone using tweezers.
Unscrew the six screws seen on the back using a Phillips 00 Screwdriver.
Remove screws and carefully place on an uncluttered surface or in a small container.
Carefully remove the back of the phone gently using your fingernails or tweezers.
Locate the yellow connection towards the top of the phone. This is directly connected to the screen.
Remove the connector by carefully prying it away from the motherboard and lifting it away from the phone
