Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Replace damaged keypad.
Запчасти
Детали не указаны.
  1. Lay the phone face down with the screen in palm of hand.
    • Lay the phone face down with the screen in palm of hand.
    • Slide the grey button towards the top of the phone.
  2. While the button is slid up grab the battery on the sides and pull up with the bottom remaining in place.
    • While the button is slid up grab the battery on the sides and pull up with the bottom remaining in place.
    • Pull the battery up vertically to completely remove from phone.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  4. Locate four screws underneath of the battery.
    • Locate four screws underneath of the battery.
    • Remove screws by turning counter clockwise with screwdriver until they pop out.
  5. Place fingers on bottom of phone near charger adapter and pry back half of bottom apart.
    • Place fingers on bottom of phone near charger adapter and pry back half of bottom apart.
    • Note: There will be a significant amount of resistance.
  6. Lift up logic board without completely removing from phone.
    • Lift up logic board without completely removing from phone.
    • Remove entire keypad from beneath the logic board.
  7. Insert replacement keypad with buttons aligned in proper holes.
    • Insert replacement keypad with buttons aligned in proper holes.
Заключение
Nichole Shaw
Участник с: 13.04.2010
1 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 18-75, Johann Spring 2010 Участник Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 членов
Автор 14 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,012
