Введение
Steps to remove LG VX8550 keypad housing
Выберете то, что вам нужно
Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
Carefully lift up on the motherboard to see the ribbon cables underneath.
Use the spudger to carefully disconnect the ribbon cable from the motherboard.
Lay the phone with the screen facedown.
The 6 slider screws are visible.
Peel back but don't remove the blue tape to access the 2 center screws.
Remove the 6 slider screws with the Phillips #00 screwdriver.
