Введение
Steps to remove the LG VX8550 scroll wheel
Выберете то, что вам нужно
Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
Carefully lift up on the motherboard to see the ribbon cables underneath.
Use the spudger to carefully disconnect the ribbon cable from the motherboard.
Lay the phone with the screen facedown.
The 6 slider screws are visible.
Peel back but don't remove the blue tape to access the 2 center screws.
Remove the 6 slider screws with the Phillips #00 screwdriver.
Remove the 2 screw covers next to the speaker with a push pin next to the camera.
Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
With the spudger, lift up under the connector to unplug it from the circuit board.
Grasp the ribbon cable near the connector and carefully slide it out of the white connector.
Carefully lift the circuit board away from the screen casing using Ipod Opening Tool.
Peel the circuit board away from the adhesive backing with your finger.
Еще один человек закончил это руководство.
