Инструменты
Запчасти
Детали не указаны.
Turn the phone off.
Remove the back cover by sliding the tab away from the phone using one finger.
Lift one side of the battery using a plastic opening tool or your fingers.
Carefully remove the battery and set it aside.
Turn your phone around and open the flip phone.
Locate the two grey rubber plugs on the LCD portion of the phone. These plugs cover up two screws.
Remove the two grey screw-covers at the bottom of the screen
Remove the screen by using the tab to eject the screen.
There is a gap between the case and the screen near the ear piece
Insert the plastic opening tool in the gap and pry the screen up.
Unscrew the four corner 3.21mm screws to separate the the top cover of the phone
Remove the top cover of the phone by inserting the plastic opening tool into the groove.
Carefully open the cover.
