Введение
The LCD screens are connected as one unit, and therefore should be removed together.
Выберете то, что вам нужно
Remove the two triangular pads at the top of the two speakers.
These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
Remove the two rubber cylinders from their shafts. These cover more screws.
This requires a little more effort, so you may need to "dig" them out.
Starting on the side with blue square, pry the faceplate upwards with the flat end of a spudger.
Continue to slide the flat edge along the seam of the faceplate.
The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
Wedge the spudger into the small gap between the phone and the metal casing of the motherboard.
Slide the spudger underneath the metal and along the edge. The motherboard should begin to rise.
Now use the spudger to lift the other side of the motherboard.
Еще один человек закончил это руководство.
