LG VX9800 Speakers Replacement
Выберете то, что вам нужно
  1. LG VX9800 Speakers Replacement, Front Keypad: шаг 1, изображение 1 из 1
    • Remove the two triangular pads at the top of the two speakers.
    • These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
  2. LG VX9800 Speakers Replacement: шаг 2, изображение 1 из 1
    • Remove the two rubber cylinders from their shafts. These cover more screws.
    • This requires a little more effort, so you may need to "dig" them out.
  3. LG VX9800 Speakers Replacement: шаг 3, изображение 1 из 1
    • Now remove the four screws.
    • The screws are small, so put them somewhere that you can easily keep track of them.
  4. LG VX9800 Speakers Replacement: шаг 4, изображение 1 из 1
    • Starting on the side with blue square, pry the faceplate upwards with the flat end of a spudger.
    • Continue to slide the flat edge along the seam of the faceplate.
    • You should hear popping or snapping noises as the faceplate is being removed.
  5. LG VX9800 Speakers Replacement: шаг 5, изображение 1 из 2 LG VX9800 Speakers Replacement: шаг 5, изображение 2 из 2
    • The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
  6. LG VX9800 Speakers Replacement: шаг 6, изображение 1 из 3 LG VX9800 Speakers Replacement: шаг 6, изображение 2 из 3 LG VX9800 Speakers Replacement: шаг 6, изображение 3 из 3
    • The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
    • Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
    • This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
  7. LG VX9800 Speakers Replacement: шаг 7, изображение 1 из 1
    • The faceplate and keypad can now be completely removed from the phone.
  8. LG VX9800 Speakers Replacement, LCD Screens: шаг 8, изображение 1 из 3 LG VX9800 Speakers Replacement, LCD Screens: шаг 8, изображение 2 из 3 LG VX9800 Speakers Replacement, LCD Screens: шаг 8, изображение 3 из 3
    • Wedge the spudger into the small gap between the phone and the metal casing of the motherboard.
    • Slide the spudger underneath the metal and along the edge. The motherboard should begin to rise.
    • There is a ribbon at the end of this groove, do not slide the spudger into the ribbon.
    • Now use the spudger to lift the other side of the motherboard.
  9. LG VX9800 Speakers Replacement: шаг 9, изображение 1 из 1
    • Lift the motherboard at an angle.
    • Do not completely remove the motherboard. Doing so will tear the ribbon!
  10. LG VX9800 Speakers Replacement: шаг 10, изображение 1 из 2 LG VX9800 Speakers Replacement: шаг 10, изображение 2 из 2
    • Gently pull the LCD screen upwards.
    • It can be tricky do this, you may want to use a spudger to pry it up if it doesn't pull up easily.
    • This step requires soldering. Only do this step if you are OK with soldering small wires.
  11. LG VX9800 Speakers Replacement, Speakers: шаг 11, изображение 1 из 2 LG VX9800 Speakers Replacement, Speakers: шаг 11, изображение 2 из 2
    • Carefully move the LCD screen in front of the logic board and use the spudger to pry against the edge of the speaker
    • The speaker should just pop right out. The only thing holding it in place is an adhesive
  12. LG VX9800 Speakers Replacement: шаг 12, изображение 1 из 1
    • Remove speaker wires from the LCD screen
    • Replace the speaker and solder back the connections to the LCD screen.
    • This step requires soldering. So only remove wires if you are comfortable soldering together small wires.
  13. LG VX9800 Speakers Replacement: шаг 13, изображение 1 из 2 LG VX9800 Speakers Replacement: шаг 13, изображение 2 из 2
    • Use the spudger to pry against the left speaker to remove it.
    • Two wires attach the speaker to the logic board, so handle carefully.
  14. LG VX9800 Speakers Replacement: шаг 14, изображение 1 из 1
    • remove the wires connected to the logic board
    • Replace the speaker and solder the connections back to the logic board
    • Only remove wires if you are comfortable soldering on a small scale.
Финишная черта
Steven Clark
Участник с: 01/21/10
29 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 16-32, Maness Winter 2010 Участник Cal Poly, Team 16-32, Maness Winter 2010
CPSU-MANESS-W10S16G32
4 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,072
