Выберете то, что вам нужно
Turn over the phone so the front screen is facing down and the back side is up.
Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
Then press down on the bottom of the battery and it should snap into place
First remove the battery by pulling the tab away from the device
Next remove the 5 rubber modules by gently prying underneath them. This will expose the screws underneath
Next remove the 6 #00 Phillips screws holding the back in place
screws: 1.43mm head, 3.61mm length
Now, slide a plastic opening tool in between the two plastic pieces that form the outside of the back case
Gently work the plastic opening tool around the edge of the case to separate the two pieces
Once the case has been separated you should be able to see the circuitry inside the phone
Remove the #00 Philips screw holding the antenna in place
Screw: 4.52mm length, 2.68mm head
Once the screw is removed, lift the small case around the antenna off
Еще один человек закончил это руководство.
