Выберете то, что вам нужно
Turn over the phone so the front screen is facing down and the back side is up.
Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
Then press down on the bottom of the battery and it should snap into place
First remove the rubber stoppers covering the screws on the back of the phone by prying them up and away from the phone.
Remove the 3.61mm length, Phillips screws from the back of the phone using the #00 screwdriver.
