Выберете то, что вам нужно
Turn the phone onto its side so the label micro SD is facing upside down.
Once on its side, lift the micro SD cover up and swivel it away from the opening.
The Micro SD card will appear as a thin plastic piece sticking out of the phone
Gently push down on the card, you should hear a click, and then it will "spring" back at you.
The card should be sticking out of the phone slightly once this is done.
Remove the card from the slot
