Введение
This guide will show you how to disassemble the LG Vu CU920 to replace a broken charging/headphone port. You will need to keep track of small screws, remove small components from the motherboard, and solder/unsolder a component
Запчасти
Детали не указаны.
Remove the back cover by firmly pressing against the indent on the back panel. Slide the cover downward and off the phone.
Remove the battery by placing your fingernail or an opening tool at the bottom edge of the battery and lift it out.
Remove the two 3.5mm screws above the battery port with a Philips #00 screwdriver.
Pull out the antenna to reveal a third screw.
Remove the 3.5mm screw with Philips #00 screwdriver.
Locate the plastic tab next to the charging port and use a plastic opening tool to gently pop it out.
Use the plastic opening tool to pry up the edges of the plastic casing. You should be able to slide it around the edge to dislodge it.
Locate these six components on the motherboard. They must be detached before the motherboard can be removed.
Gently lift the ZIF connector (black tab) holding the ribbon cable in place. When it is in the upright position, the cable can be removed from the back side.
Remove the jack attached to the red and blue wires by carefully pulling it upward from the motherboard.
Remove the round jack connected to the black cabel by carefully prying it up from beneath with a spudger or plastic opening tool.
The remaining three ribbon cables can be removed by gently lifting them by the ends opposite the cables with a plastic opening tool or spudger until they pop out.
To remove the motherboard, gently pry it up with your finger from the charging port.
Once the board has been lifted, remove it by pulling it away from the connected edge.
Unsolder the charging port located on the left side of the motherboard.
Solder in a replacement charging port.
Еще один человек закончил это руководство.
