LG Watch Sport Band Replacement
Выберете то, что вам нужно
  1. LG Watch Sport Band Replacement, Workspace: шаг 1, изображение 1 из 2 LG Watch Sport Band Replacement, Workspace: шаг 1, изображение 2 из 2
    • Prep your workstation and open the new band.
    • NOTE the little PCB tab sticking out perpendicular to the band. That will insert into the watch base.
  2. LG Watch Sport Band Replacement, Remove Screws: шаг 2, изображение 1 из 1
    • Using your Torx 4 bit, carefully unscrew the 2 screws holding in the strap. Set screws aside for later (preferably in a magnetic tray).
  3. LG Watch Sport Band Replacement, Detach Band: шаг 3, изображение 1 из 3 LG Watch Sport Band Replacement, Detach Band: шаг 3, изображение 2 из 3 LG Watch Sport Band Replacement, Detach Band: шаг 3, изображение 3 из 3
    • Now that the screws are out, slightly wiggle the strap while pulling straight out parallel to the watch base. (see 1st image)
    • It takes a little effort but you want to make sure you are pulling straight out and not bending so that you do not break off the little PCB tab that is sticking out of the end of the band.
    • Now is a good time to clean out any junk that may have accumulated between the base and band. Use a little bit of isopropyl alcohol and a swab to clean out any junk, if needed.
  4. LG Watch Sport Band Replacement, Install new band: шаг 4, изображение 1 из 2 LG Watch Sport Band Replacement, Install new band: шаг 4, изображение 2 из 2
    • Holding the band perpendicular to the watch base, insert the PCB tab into the base while wiggling the band slightly.
    • You might have to push with a bit of force as you are wiggling, just be sure to push and hold straight to avoid snapping off the PCB tab.
    • Re-attach screws.
    • Bam! Good as new!
Заключение
2 участников успешно повторили данное руководство.
Burton Podczerwinski
Участник с: 02/11/20
207 Репутация
1 руководство автора
Один комментарий
Has anybody found replacement straps? Looking at view statistics below, more and more people are looking for straps.
I'm tired of not having my Watch Sport.
I bought the Polar M600 at the same time, still using it .. but it doesn't have the great speaker of the Watch Sport nor LTE
I guess I'll replace the battery in the Watch Sport and have it at my desk for grins.
Suppose I could make some generic strap work to wear it .. anybody know what capabilities it has without the side PCBs?
Appreciate you.
Bob Schmerda - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 926
